Disables LLDP transmit mode, receive mode, or transmit and receive mode on the specified port or ports.
| all | Specifies all ports on the switch. |
| port_list | Specifies one or more ports or slots and ports. |
| receive-only | Specifies that only the receive mode for LLDP is disabled. |
| transmit-only | Specifies that only the transmit mode for LLDP is disabled. |
Enabled.
If you do not specify an option, both LLDP modes (transmit and receive) are disabled.
The following example disables the LLDP receive mode on ports 1:2 to 1:6.
disable lldp ports 1:2-1:6 receive-only
